amagro 1 Posted September 22, 2017 in Rectract Before Outer Wall not working - ZScar issues (edited) Hi, I'm having some issues with the zscar, I already try most of the possible combinations with Cura settings and I am continuing having problems as we can see in the image below. - I think the main problem that is causing the issue in the image, is the lack of pressure inside the extruder when it starts extruding the outer wall. Before the outer wall, the extruder does a long travel move, and during this travel move some pressure (filament) goes way from the extruder. Also this long travel move is strange since the the "Z Seam Aligment" is "Shortest". After analysing the gcode, I found that the "Rectract Before Outer Wall" setting is not working as we can see in the next image. - What I intent with this setting is to hold the pressure inside the extruder soon after the last extruder path (in the below layer), and then ensure that when it starts extruding (on the next layer) it will not have underextruding issues. I also found that if the "Retract at Layer Change" is activated the rectration will occur in the same x y position where the outter perimeter will start, this situation contributed again for the loose of the pressure in the extruder. - This two settings "Retract at Layer Change" and "Rectract Before Outer Wall" in order to be more eficiente must happens on the end of the last extruder path (yellow arrowhead in the gcode images). Cura 2.7.0 Tks Edited September 22, 2017 by Guest Share this post Link to post Share on other sites
amagro 1 Posted September 22, 2017 in Rectract Before Outer Wall not working - ZScar issues It seems that the "Rectract Before Outer Wall" sometimes is made. Share this post Link to post Share on other sites
smartavionics 134 Posted September 22, 2017 in Rectract Before Outer Wall not working - ZScar issues Could please post a link to the gcode so I can have nose around, thanks. Share this post Link to post Share on other sites
amagro 1 Posted September 22, 2017 in Rectract Before Outer Wall not working - ZScar issues https://www.dropbox.com/s/r1l4rqbigvdlzks/3DBenchy.gcode?dl=0 Share this post Link to post Share on other sites
smartavionics 134 Posted September 22, 2017 in Rectract Before Outer Wall not working - ZScar issues Thanks for the gcode - I've found the bug (it's not one of mine!), it's triggered by the combination of retract before outer wall and outer wall printed before inner walls both being enabled and the end of one layer being some distance away from the start of the new layer. I will submit a PR that should fix the problem to the Cura devs. Share this post Link to post Share on other sites
smartavionics 134 Posted September 22, 2017 in Rectract Before Outer Wall not working - ZScar issues PR raised, see https://github.com/Ultimaker/CuraEngine/pull/610 Share this post Link to post Share on other sites
amagro 1 Posted September 25, 2017 in Rectract Before Outer Wall not working - ZScar issues Really appreciated @smartavionics Share this post Link to post Share on other sites
ghostkeeper 54 Posted September 28, 2017 in Rectract Before Outer Wall not working - ZScar issues And it's merged. Thanks for the debugging, guys. Share this post Link to post Share on other sites
amagro 1 Posted November 9, 2017 in Rectract Before Outer Wall not working - ZScar issues Hi @ghostkeeper, The issue with the "Retract at Layer Change" that is happeing in the same x y position where the outter perimeter will start (that contribute for the loose of the pressure in the extruder) was not solved, only the "Rectract Before Outer Wall" was corrected. As you can see in the image, after the last extrusion (and here is where the retraction must occour) there's a long travel move, then a retraction happens, goes to new layer and prime, all this on the exact same place. - Share this post Link to post Share on other sites
amagro 1 Posted November 9, 2017 in Rectract Before Outer Wall not working - ZScar issues Here's the gcode: https://www.dropbox.com/s/z6dqigty8etkdqk/3DBenchy_print2.gcode?dl=0 Share this post Link to post Share on other sites
smartavionics 134 Posted November 9, 2017 in Rectract Before Outer Wall not working - ZScar issues Hmm, I thought that was sorted, obviously not. Let's take another look at that... Share this post Link to post Share on other sites
smartavionics 134 Posted November 9, 2017 in Rectract Before Outer Wall not working - ZScar issues Just doing a quick test and it's working for me. This image shows the retracted travel move (yellow) to the start of the outer wall. Will continue to investigate. Share this post Link to post Share on other sites
smartavionics 134 Posted November 9, 2017 in Rectract Before Outer Wall not working - ZScar issues (edited) Edit - no, I was wrong it's actually working OK (duhh, I forgot to turn on the retract before outer wall setting!) So at the moment, it's working OK for me. Edited November 9, 2017 by Guest Share this post Link to post Share on other sites
smartavionics 134 Posted November 9, 2017 in Rectract Before Outer Wall not working - ZScar issues And, guess what? You made the same mistake! In your gcode file it has the evidence: travel_retract_before_outer_wall = False Share this post Link to post Share on other sites
amagro 1 Posted November 9, 2017 in Rectract Before Outer Wall not working - ZScar issues (edited) In this gcode I was not using the "Retract before_outer_wall" option (but I know that it's already working), I was testing only the "Retract at Layer Change". Edited November 9, 2017 by Guest Share this post Link to post Share on other sites
smartavionics 134 Posted November 9, 2017 in Rectract Before Outer Wall not working - ZScar issues Ah, sorry, I misunderstood (should have read your posting more carefully!) Share this post Link to post Share on other sites
smartavionics 134 Posted November 9, 2017 in Rectract Before Outer Wall not working - ZScar issues I have modified the mod we made earlier to take into account the retract at layer change setting. A quick test appears to do the right thing so I will create a PR and then the Cura devs can decide whether to incorporate it or do something different. Share this post Link to post Share on other sites
smartavionics 134 Posted November 9, 2017 in Rectract Before Outer Wall not working - ZScar issues See https://github.com/Ultimaker/CuraEngine/pull/650 1 Share this post Link to post Share on other sites
