Printcore profiles
rebekah_harper
Posted · Printcore profiles
Hiya all,
I was wondering if there was any way to create a printcore with user defined nozzle size.
It seems that when slicing it initially with the printcore size then uses the extrusion width to calculate the paths.
this means that if I use 0.25 or smaller I lose details.
so I need core profiles that I can edit to suit the nozzle size I am using.
cheers
Becky
