I sure don't mind doing that. Can you point me to the config file or what the extension is?
To the powers that be, would it be possible to enable the 'print one at a time' sequence for the condition of printing with one extruder, and disable it if two are being used? That would seem (on the surface) to be a quick work around.
Pete
tinkergnome 929
https://ultimaker.com/en/community/50595-cura-27-beta?page=last#reply-189579
only possible solution a.t.m.: if you don't worry to break something, edit the configuration file for your printer with a text editor and enable the "print_sequence" setting.
