Wall thickness/horizontal fusing
ViennaBlood
Posted · Wall thickness/horizontal fusing
After some testing it appears that Cura is not fusing multiple walls properly.
I set the nozzle diameter to 0.4mm and extrusion width to 0.4mm. Then I set numer of walls to 3. This results in a calculated wall thickness of 1.2mm.
If I read the generated G-code correctly the traces for this wall are 0.4mm apart.
I also tried it the other way around: I set wall thickness to 1.1mm, with an extrusion width of 0.4mm (hoping this would cause cura to "crush" the walls together, fusing them). In the resulting G-code the walls are 0.4mm apart, producing a 1.2mm wall.
This means that if my extrusion multiplier is properly calibrated those 3 walls are barely touching. Test prints seem to confirm this - unless I set the extrusion multiplier to overextrude by more than 5% wall adhesion is very bad.
So it seems Cura is relying on overextrusion and/or wobble to fuse the walls.
Slic3r seems to do this differently and offers a very good explanation of this problem here: http://manual.slic3r.org/advanced/flow-math (sections "Extruding on top of a surface" and "Spacing paths")
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 1 reply
        • 13 replies
