Software cura 2.7: ¿Bug filling TPU?
seramup
Posted · Software cura 2.7: ¿Bug filling TPU?
¿Hay un bug en el relleno cuando seleccionamos TPU?
Realmente si seleccionas el relleno 100%, si te lo hace. Si seleccionas cualquier densidad de relleno menor, no se corresponde con el resultado final.
Is there a bug in the padding when we select TPU?
Really if you select 100% fill, if you do. If you select any lower fill density, it does not match the final result.
    If 100% is working correctly and filling 100%, but any lower infill looks sparse or stringy, then you may have your print speed set too high.
    If its like S3D, then 100% infill speed is printed at Top/Bottom speed, whereas lower infill percentages are printed at full speed. And for TPU, that may be too fast.
    So try lowering the infill speed to your top/bottom speed.
    Just a WAG.
