Hi again, I FINALLY MANAGED TO UNCLOG THE PRINTCORE.
(multiple celebration emojis here)
I began with hot and cold pulls with PLA at 230°C and needle poking through the nozzle and somehow, a brownish mixture came out of the nozzle. Just a bit, but it was enough to give me some king of hope. I kept doing it with a piece of blue PLA to see if the color would flow through the nozzle. Here's how it looked like:
I switched between a blue and a yellow piece of filament to see if it was getting any better. As you suggested, I «vigourously move the PLA in and out the extruder (2 or 3 times) then press hard and yank out.» Eventually, that combined with the hot and the cold pulls, chunks of burnt PVA began to stick to the PLA. This is the biggest one:
I finally just kept the nozzle's temperature at 230°C and kept applying pressure with a piece of PLA filament at the top and the needle poking the end whenever nothing came out. A bit like this:
After 3h of trying plus everything I did before my post, the printcore was finally free. Here's a look of the some tips of filament I used:
I would say the the most helpful part was applying pressure at the top and sticking the needle whenever nothing came out. I got them at the local drugstore, they're used for insulin injections.
And that how it ends, I hope.
rebekah_harper 60
age could be a factor if it's got moisture in it.
PVA will go powdery at high temperatures. so I think the 260 was not a good idea. in the maintenance part of the menu there is the hot and cold pull. I recommend you use that. at least you can blame Ultimaker.
I use PLA for the hot and cold pull.
insert and use pliers to force it through. if nothing comes out use a strand from a wire brush and poke the nozzle. I think you'll be a while doing it again and again.
I sometimes vigourously move the PLA in and out the extruder (2 or 3 times) then press hard and yank out.
do this a couple of times and then cold pull as per the machine's direction. then do the hot pull again. you'll have to do this quite a few time unless you get this.
Please take your time and do this a lot. even if it looks like its free flowing, keep doing it cause there should be a lot of brown PVA in there. +- 10mm of the nozzle worth.
I don't think the problem is the feeder but a consequence.
Please use this Reel casing
this is until I make and test a new and better one.![5a334012539b3_CASECOMPLETE.thumb.jpg.b1d10378e2fde8b2d882c882255a1da0.jpg](//content.invisioncic.com/ultimake/monthly_2017_12/5a334012539b3_CASECOMPLETE.thumb.jpg.b1d10378e2fde8b2d882c882255a1da0.jpg)
hope you manage to sort it out. it isn't lost just needs patience and time spent on clearing the blockage.
Rebekah Anderson
