Cura 3.0 [Modify G-Code] function does not work
JasonWhite
Posted (edited) · Cura 3.0 [Modify G-Code] function does not work
I have installed Cura 3.0 ( my OS is Win 10), like its new interface and features.
But after checked all icons function, some icons can not change color to blue when I moved muse cursor on them, so they cannot be clicked and run...
Could somebody help me? any thoughts?.
Thank you!
Extensions -> Post Processing -> Modify G-Code
Extensions -> Update Checker -> Check for Updates
    • 8 months later...
    Posted · Cura 3.0 [Modify G-Code] function does not work
    As a workaround, use the cursor-keys to navigate through the menus. We haven't quite figured out why this happens on some systems, but there's a good chance it will finally be fixed in the next release because the UI framework that's used in Cura is upgraded to a much newer version.
        • 21 replies
