How to customize the temperature in Ultimaker 2+?
dennispo
Posted · How to customize the temperature in Ultimaker 2+?
I want to customize the print temperature and build plate temperature, but I found there is no related settings showing when I enabled just like the picture above.
Software version 2.4.0
Hope you guys know how to set temperatures.
    As the tooltip says temperature setting has been disabled by the gcode flavor which is Ultigcode by default. Change the flavor to RepRap gcode and you will be able to override the settings in the UM2+ with settings from Cura.
    And if you don't want to change the flavor, the temperatures in basic settings for materials are stored on the printer, you can change theses settings by going in the materials menu on the printer.
