Cura 3.0 can't change infill density for extruder 2
leliep
Posted · Cura 3.0 can't change infill density for extruder 2
When I try to change the infill density of extruder 2 it doesn't change, see layer view in screenshot. For extruder 1 this works just fine.
Am I doing something wrong or is this a special feature of Cura 3.0 (seen already with Cura 2.7)?
5a334035a4b4c_Bildschirmfoto2017-10-19um10_09_18.thumb.png.c230831fdd68078a43a3716b250f5614.png
    You beat me to it :O
    Yes, because of problems with extruder 1 I printed the model with extruder 2.
    As you saw, I changed the setting for extruder 1 instead of extruder 2. Wasn't aware that the infill can be set separately, stupid me.
    Thanks for pointing that out!
    From the image you attached, it looks like you are modifying the Infill Density setting of Extruder 1, yet your model is being printed by Extruder 2. :D
        • 4 replies
