Filament guide UM3
Ziogianni84
Posted · Filament guide UM3
Nope. The filament has to go through the shackle.
Hi, I know that indeed it was specified in the post's introduction "Never mind...." What I meant to say was that I see the whole filament guide being loose, not the filament itself. There's a small tab in the middle of the shunk, between the two spools, which I cannot hook anywhere. So if I apply pressure on the far end of the filament guide it swings.
    Oh sorry, I must have overread this. The material guide, as the part is officially called, has indeed quite a lot of play. One could improve that a bit by adjusting the mold injection tool. However, a bit too much play is better in this case as not enough play.
    Don't worry about the material guide falling down. As long as there is a spool on position 1 it cannot fall down unless it is very exposed to people touching it accidentally. The latch is just for limiting the movement of the spool in position 1.
    Posted (edited) · Filament guide UM3
    Thanks! Just because I'm quite curious... regarding the latch, should it be closed in any way? Or should it work as is like a sort of stopper tab preventing the material guide from moving around (like actually you already explained)?
