Posted (edited) · Improve PLA settings (after 1 year using ABS)
Dear friends,
I am new to the UM community with an original UM2 am trying to use (no Olsson block yet).
I spent 1 year using exclusively ABS at 260-270°C (over other machines: Tiertime UpCube et UpMini),
and I am definitely new with PLA and how to get it work.
As a start I decided to do this voronoï eggcup: https://www.thingiverse.com/thing:400683
which has several complicated aspects to deal with (shape, angles...), and I am a bit desapointed by the first result, many dirty stuff straight out from the machine, as you can see:
What I have done before printing this "crash test":
- Lubricate all the axes of the machine,
- Calibration tray,
- Degreasing tray + thin layer of lacquer (strong fixation),
- Cleaning nozzle "atomic method" 3 times until obtaining a clean nozzle,
- Machine Update latest firmware (2.6.2 Jul 2017),
- Update latest version CURA (3.0.4),
- Installation of an official Ultimaker white PLA filament spool.
My settings:
- Nozzle 210°C
- Bed 60°C (after having read through the UM forum, instead of 75°C by default...)
- With BRIM
- Layer thickness 0.10mm
- Infill 10%
- Speed 60 mm/s
- Fans 100%
- Retraction enabled (speed 20mm/s min. - distance 0.8mm)
- No support
The first layer has also deformed, the brim has retained it a little:
I think my problems are due to too high extrusion temperature, making the PLA too liquid, causing the first unstable layers + visible dirt.
I think I have to lower the extrusion temperature.
What do you think ? Do you have any optimization tricks?
Thanks in advance for your feedback :)
    It will really depend on the PLA you use (Brand, colors, etc). But for the most part, I find that printing between 190°C (on the low end) to 205°C (on the high end) and mostly 195°C has solved a lot of issues.
    You may have to change the speed to a bit slower to help it out.
    Keep in mind that I am on a UM3E and that may make a difference, but I think it could be a start for you. I dual print almost everything and do not use the priming tower anymore as well as rarely use the ooze shield.
    I am also on Cura 3.0.4. That will make a difference too.
    Thanks a lot @kmanstudios !
    I figured out after testig that those settings works well:
    Nozzle 195°C
    Bed 50°C
    Print speed 50 mm/s
    Travel speed 250 mm/s
    Infill 25%
    Thickness 0.10 mm
    Retraction distance 4.5 mm (on the machine)
    Retraction speed 25 mm/s (on the machine)
    But am totally lost concerning retraction properties on the software side.
    I feel completely lost, there are so so many different parameters, specially in Cura.
    On my previous machines with 1.75mm filament and ABS I never had to deal with that. The filament was always going down without any stringing/oozing.
    So either the concept and the settings of retraction are new for me.
    Now with PLA, this seems more like a "living" material a way trickier to set, even at lower temperature (was around 270°C for ABS...)
    And all seems kind of tricky, because there are parameters on the machine itself (retraction length and speed) and tons in Cura...
    So far I ended up doing tests with various settings as shown:
    From left to right, the settings in Cura 3.0.4:
    Machine 1.0mm I 25mm/sec with CURA RMT: 0.8mm MRC: 90 MEDW: 6.5mm
    Machine 4.5mm I 25mm/sec with CURA RMT: 0.8mm MRC: 90 MEDW: 6.5mm
    Machine 4.5mm I 25mm/sec with CURA RMT: 5.0mm MRC: 150 (!) MEDW: 4.5mm
    *RMT: Retraction Minimum Travel
    *MRC: Maximum Retraction Count
    *MEDW: Minimum Extrusion Distance Window
    Posted · Improve PLA settings (after 1 year using ABS)
    By the way @kmanstudios, are there some tricks in Cura 3.0.4 to deal with ?
    I would apreciate to have your opinion.
    I spent the last night scrolling the forum, and it seems like finding the right version of Cura (without bugs or so) is a sport hard to handle...
    Many users have several versions, using them in parallel, depending of the released numbers. Some time having trouble or prefering previous settings, etc.
    (Also as a new Ultimaker user, it was pretty tricky though to find some basic info over the forum without any search field, I never found it, I used Google instead... )
    I like 3.0.4.
    Retraction is not something I mess with too much. Usually, cooling the material works well.
    Maybe try 190?
    I may have a lot of posts, but that is because I am a blabbermouth....not super experienced in the ways of the Print Force.
    Yeah,
    But still :)
    Using 190 C temp leads me to very soft under extrusion (feeder grind sound + small holes on brim) while 195C seems perfect for me, 200C slightly too much...
    When I received it, my machine was set as so, available on the display in maintenance :
    1mm retraction length
    25mm/s retraction speed
    I have read over the forum that people achieve good things with 4.5mm length at 25mm/s.
    What are your machine settings for instance ?
    Depends on the material and layer thickness.
    As you can see, right now it is set for PLA, 0.2mm layer height.
    Thanks, I see.
    So, those are the one for cura.
    Why are the retraction settings on the machine different ? Could you compare to what is written on the display of your machine, going through the advanced settings ?
    Are the machine settings or cura settings which are used when printing ?
    Thanks in advance !
    I am on a UM3E and as far as I know, Cura runs all of that.
          • Heart
        • 4 replies
