Thanks for the incredibly fast response.
I always measured the voltage between black and red. How can I measure it with only one wire? (I have a voltmeter, but are not so experienced with it ... ;-) )
I think it's interesting, that the voltage is not correlating to the given rpm's. so, voltage for 70 rpm (m106 S70) is higher then for 200 rpm... it seems to have no correlation between voltage and rpms.
I use the printrun to communicate with the Ultimaker.
gr5 2,330
The red wire is 14 to 19v but is the black wire 0V? It should be. Or was the 14V the voltage between the red and black wires?
