I suddenly have a print quality issue, only with the top layers
Posted
· I suddenly have a print quality issue, only with the top layers
I see 4 issues. which issue do you refer to?
The "hole" issue in the top part is likely due to a recent change in Cura 3. There is a ton of discussion in github. The fix for now is to go back to Cura 2.7:
gr5 2,230
https://github.com/ultimaker/cura/issues/2665
If it's one of the other issues maybe circle which issue is bothering you or describe it - maybe:
infill overextrusion bordering shell
random lines crossing top surface (e.g. 3 of them on lower pic)
when print stops it leaves a bump and thread
