NINJA ARMADILLO
geoff
Posted · NINJA ARMADILLO
Has anyone any success printing smaller parts with NINJA ARMADILLO (TPU type of filament, I think) on a Ultimaker 3. I seem to have problems with the model partially 'melting" as it prints, the nozzle seems to quash the print maybe. the part is a buffer measuring 6mm diameter 5mm long, so it is small.
I have tried Ultimaker TPU 95 settings and Ninja recommendation with the same problem
But it prints ok with PLA??
The filament is 2.85mm
Any thoughts greatly appreciated
    I have only tried a tiny bit with Cheetah or Armadillo. And, nothing that small. But maybe if you cut the temp back a bit?
    That would be my first try and then second would be to slow down the print speed.
