On Ultimaker 2+ all engines stopped working at once.
Y1B
Posted · On Ultimaker 2+ all engines stopped working at once.
Hi @Y1B,
I moved your thread to the hardware - troubleshooting section, I think you'll find more help here. Is anything else still working, like the screen?
Otherwise, I would suggest to check if all cables are seated properly and if the LED is on, on your power supply unit.
