gr5: thanks for the advice, I've tried as you suggested:
cura
(<type 'exceptions.ValueError'>, ValueError("invalid literal for int() with base 10: '?'",), <traceback object at 0x42d8cf8>)
Flashing 89584 bytes
Verifying 89584 bytes
I see the tx/rx lights on the arduino flashing as you'd expect during this process, so I'm fairly sure this has worked.
I re-insert the arduino then re-power the UM - still the same, UC just gives the rows of blocks and nothing for the rest - cura reports communicaiton failure from first-run wizard. I've also tried this with all the wires disconnected from the UM apart from the UC & fan and tried with rebooting PC between flashing and re-connecting things (as sometimes USB doesn't seem to reset). Not sure what to do next really, open to suggestions?
gr5 2,178
This may sound strange but SEVERAL people had the same problem in the last few weeks and the solution for ALL of them was to carefully (very carefully) remove the arduino board form the main board, then plug the usb into arduino board only (usb powers up arduino just fine). Then upload the firmware one more time. Then unplug, power down and evern more carefully now attach the arduino board back to the main board.
I know it sounds bizarre but if you search these forums it fixed things for a few recent kits.
