Hot end fan insufficient voltage.
Wert
Posted · Hot end fan insufficient voltage.
Hi, everyone.
I have Ultimaker 2+. It worked fine for a year, then hot end fan began to rotate slowly. I replaced it. The new one worked for three weeks, and then the same problem occurred, afterwards it stopped. I measured voltage. It was 2.53V both at the end of the cable and on the main board, instead of 5V as it should be. Have anyone faced similar problem? Any advices?
