Posted · Will a UMO+(as produced) and Cura 3.1 work together?
I am the kind of person that upgrades to the newest software avail. I am using this on MAC OS
I downloaded CURA 3.1 and tried to use it with my UMO+.
As soon as I started the software it asked what printer I was using. I put that info in and it wanted to do a system check. Everything worked in the first window as it should..... then I thought i should do a bed level with the new software..... that is when it got weird. It went through the leveling process as usual BUT it was hovering 10mm or so higher than the print bed. I went back to v2.3.2 and it leveled out perfect. ANY THOUGHTS? please help.
