So, one more observation. If I restart the Wi-Fi AP while the Ultimaker is on I will get an IP in the correct network 192.168.2.XXX.
If I restart the Ultimaker and the AP has been on for several hours I will get this odd 169.254.54.29 IP address.
The odd 169 address is the address the printer will take if it never gets an address from the WiFi router.
Can you check if your router has a feature called "band steering"? We've noticed that this feature in WiFi routers is causing problems for the WiFi in the Ultimaker3, depending on your WiFi router.
Yes the HPE OC20 dose have the band steering feature. Hopefully the wifi connection is only a temporary solutions until the Ultimaker finds a more permeate home.
Jeff922 0
Here is a image of the IP address that the UM3 is getting via my AP.
Edited by Jeff922Link to post
