UMO+ Replacement parts
Cbocka
Posted · UMO+ Replacement parts
Hello everyone,
The other day I found my pt100 sensor had broken. I started disassembling the hot end so that I could pull it out and accidentally stripped out the set screw in the aluminum block. Long story short, I am in need of a new aluminum block, pt100 heat sensor, and hotend heating element. I haven't had any luck finding replacement parts. Is there any recommended website that I should go to for replacement parts? I live in New York, not sure if this helps anything. Any input is greatly appreciated.
Thankyou,
Christian.
