Thanks for the reply. " retract on layer change " is unticked.The inner wall you are referring to doesn't exist with a cookie cutter since the walls are only 1mm thick as it is. I was hoping someone could tell me how to make it "randomize" the starting points.
Thanks
gr5 1,876
Well make sure the "retract on layer change" feature is off. That will cause exactly what you describe.
I believe this is called the "z seam" and I believe you can randomize this location - I think it's a feature somewhere in cura.
Although the "z seam" is more often created by moving from shell to infill (not one layer to the next which in most versions of Cura I belive happens interior to the part so it's not visible).
