Thank you all for your replies.
Mine really didn't slice it properly, tried both 3.1.0 and 3.0.4 versions, even I had the "Remove all holes" unchecked.
Resetting profile settings to default helped, so I compared the before-reset/after-reset settings and found out that it was caused by "Make Overhang Printable" option enabled.
thanks again for your help.
kmanstudios 1,120
glad you found it.
burtoogle 515
It works OK with the latest development code which isn't that far removed from 3.x:
