Hi Sander,
yes, certainly I will start with 2,85mm.
Only if it would be something easy (and cheap) to do I would consider using a 1,75mm conversion -
just to get rid of all that filament I still have around here;-)
- 1
Hi Sander,
I'm sure you could also sell all your 1.75mm filament online.
For sure I could do that, Brulti.
Maybe I'll try to - but it would be quite a loss, anyway.
Still comparing options.
There are a lot of 3D-Printers around.
But it looks like none of them is without drawbacks.
So I try to find the "least worse compromise";-)
And to be honest - at the very moment I am strongly considering buying a bunch of parts and building my own printer.
Which would give me one big advantage - I know who's to blame when it does not work...
While I must admit that the Ultimaker 3 does look promising.
Oh, options, oh options ....
So just to end this thread - and assure all of you there are more to come from me...;-)
Got an offer today which was quite appealing so I thought to myself - let's give it a try.
Now I look forward for "yellow santa" to ring at my door tomorrow -
delivering an UM3e and some stuff to get me started with it;-)
Again, thank you all for your answers & thoughts!
SandervG 1,521
There are more things to take into account. In the '2.85' bowden tube (the inner diameter is actually 3.16mm) you almost completely undermine your retraction settings if you feed 1.75mm through it and lose almost all control over your filament. The feeder also is dialed in for 2.85mm filament, not sure how it would respond to 1.75mm filament. Then, at the end of the line, there is also the print core.
Anyway, I would definitely stress to start off with regular 2.85mm filament, how it is intended to be used. After a while, when you are familiar with the Ultimaker 3Extended, ask yourself if you got used to 2.85mm filament and just continue to use it or that you still want to convert. Perhaps the need will be gone then and you'll use it as intended. If not, there is a lot of help here to help you out
