Hello SandervG,
thank you for your reply & the infos!
Regarding the experience with Raise3D - that is something I do not want to have again.
So I'd be interested in learning how Ultimaker has set up it's product care?
Would I always need to contact the reseller? Does Ultimaker have a fixed partner for that per country?
Which then would have to contact Ultimaker? Or can I contact Ultimaker directly to solve (hopefully never happening) defects?
Having to send in the printer to a reseller who then may or may not sends it to the manufacturer and vice versa is a time consuming procedure.
As I am mechanically and electrically experienced, I quite often would be able to fix things myself with the right parts being made available by the manufacturer.
But when it comes to major mechanical defects, I will depend on the manufacturer for sure (e.g. exchanging and re-calibrating a Z-axis might be tough;-)
Do you know PolyMaker's PolyFlex? Is that printable with the UM3e?
SandervG 1,521
Hi @Bossler,
Welcome to the community!
Looks like I am the first one to reply. Usually, this thread is used when people want to sell, so not that often monitored by most members of the community.
But you've definitely selected the right category based on its description.
I'm happy to hear that you are considering an Ultimaker 3 Extended when looking for an alternative for your current 3D printer, the Raise3D.
Regarding your experience of why you feel like you need to cross the Raise3D of your list, I like to think we have always helped our customers where possible (and reasonable I must add). Outside of that, we also have this awesome community to help everyone in need, if help can be offered in the form of advice and aid.
One unbiased thing that can vouch for this I think, is that if we did a terrible way of interacting with our users we would never have such a community of 3D printing experts.
Re your concern with 1.75mm filament; yes. That is a bridge you probably will have to cross and then burn. Welcome to the land of 2.85mm filament. I would not recommend to mod your Ultimaker 3 into 1.75mm filament. There are some mod (I know @gr5 sold one) for the Ultimaker 2(+), but they are rare. Since we are working with a bowden tube, 2.85mm filament works just slightly better.
1kg reels; you can. It kinda depends on the diameter of the hole in the reel, but you can print your own reel holder if it would not fit or put the reel on a lazy susan. There are decent alternatives outside of the regular spoolholder that is included with the Ultimaker.
Closed door; also yes! Check out this link
In general, yes it works. But it is definitely more tricky than regular filament and has some more limitations. It kinda depends on how flexible the filament needs to be and if there are any special requirements to it. You can find a variety of topics about flexible filament on our forums with various tips and tricks.
Woodfill materials are no problem. It is recommended to use a bigger nozzle so the fibers don't block your nozzle that easily. With the Ultimaker 3 you have the choice of an 0.8 print core
If you have any further questions, please feel free to ask and by all means poke around in our community! Looking forward hearing from you!
