tinkergnome 927
Looks like the option "Avoid printed parts when traveling". It's in the "Travel" section of the settings, you can also specify the distance to the part.
But you have to make these settings visible first like described in the manual.
1
burtoogle 515
Combing (no-retract travel moves) does not cross the air boundaries between parts. In your image above, there are two parts (a part as far as Cura is concerned is a region that is surrounded by air). So it will do a retraction in the above travel move. Do you have z-hop enabled? If not, perhaps enabling z-hop will make the travel occur in a straight line.
