printer export/import
gorischek
Posted · printer export/import
Those are print quality settings, not printER (machine) settings. I don't know which settings are in the quality profile export by head, but it could be that start/end G-code is not one of them. Anyways, this feature didn't change between Cura 2.x and 3.x.
    My bad.
    I tried something that appears to work, but not 100% sure it's reliable. I added a machine I didn't have, a Prusa in this case, I then edited the start gcode for that printer and added a word to it. I loaded a model and then saved as project. I then removed the Prusa-printer and restarted Cura. I loaded the project file, the Prusa machine was added and the unique word was present in the start gcode. So maybe a workaround?
    Thx a lot! The workaround with importing a project works.
        • 24 replies
