So the power supply that comes with the UM2 won't be able to get you to 150C. If you enclose the printer you can get up to maybe 110C at the most. Rajil I believe bought a separate heater for his heated bed (he has both UM heated bed and his own stacked together I think). That separate heater is probably run on AC power, not DC, and it is probably at least 300 Watts. And it probably came with it's own temperature controller.
Why do you want the bed to go to 150C but you don't mind the nozzle only going to 260? In that topic that I posted above it talks about bed and nozzle temperatures needed to print several materials.
gr5 2,210
Yes. This guy has it. Or you can build your own. Contact Rajil in this topic:
But I think he has things that may be incompatible with your printer - I'm not sure if he has a pt100 temp sensor in his primary head and he has a second heat (that he doesn't use). So maybe best if you just build your own. To get started on building your own marlin try this topic:
