Posted
· Part on bed but no layers and 0 print time
So that version of cura you are using generally requires walls to be at least 2X the nozzle width. Try changing nozzle width to 0.1mm just as a test to see if it suddenly decides it is printable. If that works and the walls are between one and two nozzle widths then you could consider cura 3.1 which has a feature to print walls thinner than nozzle widthX2. Or you might be right on the edge and can lie a little and tell your printer that your nozzle is 0.35 (make sure to set shell to 0.35 or 0.7 because if shell is 0.8 then bizzarley cura will do 0.4mm line width even though you tell it the nozzle is .35 - cura is weird that way - best to ALWAYS make shell an integral multiple of nozzle width).
gr5 2,025
