The name change is fine. The Cura version I'm using is 14.07 provided by my printer manufacturer JGAURORA. I have tried to save to my local hard drive and to a removable disk and neither have worked. The part that I'm trying to save is very small and I waited 2 or 3 minutes for it to appear.
SandervG 1,522
Hi @nlkirchn , where are you trying to save the gcode? On your computer or a removable disk of some kind?
How long have you waited to see if perhaps the software needed a couple of more seconds, and last did you actually press the save button and not mistake the automatic slicing for saving? (Which version of Cura are you using?)
Thank you!
