kmanstudios 1,117
Just so's you know, Unless I change types of materials such as PC to PLA or something else with radical heating temps, I rarely have to clean my AA core other than about once a month or so.
The BB core is a different story as PVA is so susceptible to any moisture, it can tend to be a bit more bothersome. And, unless I do a print that is about 6 days or so, I do not have to clean after every print on that.
I am not sure about the knocking noise. That is new to me. The only time I hear knocks is when the print head is violently shaking during a tight fill. And, that has remained constant. Other than that, I found doing a gazillion retractions can cause a bit of noise too. Not just the beeps.
As for the grinding, I am having a hard time believing you could not find anything about that.
Basic Google Search...typing time to find only.
Digging a bit further for all of two minutes I found this. And this. And this. And I am stopping at this point for that one. There is a bunch more.
As for the filament not loading, was it cut with a taper to allow easier guiding? Was the filament straightened a bit to make sure it did not have any curl that could jam it? And, did you make sure that when you loaded the filament you put it in high enough to see it through the Bowden tube? If not, then it is possible, it caught on the entrance to the tube and started a situation that escalated.
What was the feeder tension set to when you got it? Middle? High? Low?
So, not a lot of information to go on there. And, for the record, I now have two of these monsters and I can get amazing prints. There are so many variables that can go into getting prints to look nice. But, this is my very first print, vase mode with a Batman statue:
That is a US Quarter for size. No experience with 3D Printing, no idea what I was doing, nothing. Is it a great print? By no means. But is it a great first print for a complete noob, especially compared to what I have seen printed for people by other places, oh, you betcha. And, why so small? Impatience to see my first print and this was done in vase mode with no supports.
Edited by kmanstudiostypelexia
Bossler 8
So now I do have the UM3 5 days over here.
And the frightening thing is - it got way less noisy!
Why frightening?
Because this tells me something has been "worn in".
And worn in parts always wear out somewhen...
So let's put it that way - it is working fine now but I am concerned about how long it will do so...
I really do not have a clue what was causing the noise - but I do watch the UM3 closely to find out whether there are any loose parts.
What I've seen: the left rear (short) belt was scratching on one of the wires of the Y-endswitch.
This is not very professional, guys from Ultimaker.
You may want to consider a slight change in the way you mount this endswitch resp. the cable... a groove in the housing could help, for instance...
As far a the printing performance is concerned so far, this printer is a mixed bag.
It can produce quite nice prints, yes.
The dimensional accuracy is something I need to work on - seems it's overextruding. Even with original Ultimaker-Material - which I would not expect.
After all that's what I paid for - a tested combination of material & machine, right?
What also is a bit annoying is the frequent need for cleaning the hot ends.
I am not used to have to clean the nozzles after nearly every print.
That makes this machine a good choice for hobby-printers - but it's advertised as production-type-machine, isn't it?
My suggestions would be to revise the filament unload-procedure.
As I did write in another thread, I have had very good results with pre-heating, pre-loading, and then unloading type of operation.
I've tested that on the UM3 by using the "move" command before unloading and can assure you that this works way better.
As you guys seem to like to automate everything for users convenience I'd suggest to implement this kind of procedure as
automatic sequence:
Unload Filament = Pre-Heat Printcore; Extrude until <acknowledged by user>; Unload.
For loading filaments it would be good to have the option to load a "manual"-material where the user could choose the load temp by the wheel.
Could default to 200°C as a good point to start.
Would save some time when you prefer to work without the NFC-feature and with "strange materials" like PTEG ...(as I do).
So far for now.
