Very, very late to the topic... but for this application, I'd use nylon anytime. Just be careful that your final dimensions fit, Nylon is somewhat prone to shrinkage - better print slow (~35mm/s for all speeds) and make some tests to determine if you need to use scaling or the horizontal expansion setting.
cjryker06 0
PC is technically stronger than any form of co-polyester like CPE/+. Nylon has good strength and more give if that is needed. Co-polyesters tend to be more rigid.
