2 hours ago, kmanstudios said:You should remove the back plate at the top rear of the printhead and make sure the connector is fully seated into the printhead. It can come a bit loose and this will help resolve that issue. This is a bit more elaborate in explanation.
Ah, cool. Thanks for that.
kmanstudios 1,120
Regarding #1:
@fbrc8-erin did a great job of explaining it. (It seems the tagging did not work like it should)
If you are printing very hot and keeping the heat in, it can help make the plastics a bit loose and need to be reset.
Regarding #2:
Yeah, seconding that one. Especially, as you state, you are trying to clean things up and it just goes about its business.
