Tiny pieces of dust or wood that are difficult to see can cause partial blockages. That's the most likely problem. Best fixed by unscrewing the nozzle (gently! and while at 200C! Consider using oven mitts as you are less likely to damage it) then heating the nozzle with flame to burn anything in there out. Not so hot that you melt the brass.
Alternatively is it possibly you have been increasing layer thickness or speed recently as the volume of filament that can pass through the nozzle is limited so if you switch from layer height .2 to .3 you will hit this limit likely or if you speed up from 100mm/sec to 150mm/sec with .2mm layers you can also hit htis limit.
gr5 2,332
