Yes i'm using 1.75mm and i set this in filament and printer settings
- 3 weeks later...
I've been having this problem recently myself, started with new version of cura. Not sure if it's the same issue, new files I've been slicing are starting the z height higher then it should be, and not squishing the layers properly. Printing old files indicates it's a slicer issue (the old files print fine). I don't have a solution yet, but figured I would mention it as I look for a solution, if you have any suggestions.
- 2 weeks later...
Maybe it is a relative/absolute problem in height? i can't solve this problem till now.
It looks like the offset is ignored an the table moves to a set height.
gr5 1,611
Are you using 1.75mm filament? If so you have to tell cura that. I think cura defaults to 3mm filament.
