thank you for the reply. Is there a way to do what I am trying to do? Showing the crack in the nozzle is kind of essential to what I am trying to produce. while it just come down to printing the model and trying to cut the crack out after the fact?
thanks again.
Mike
ahoeben 1,981
You have created a "broken" model that is probably no longer "watertight". You can use applications such as Netfabb or Meshmixer, or online services to repair the object.
Inside Cura, you can use the "X Ray view" to see if the model has these sort of issues (they will be drawn red in the X Ray view), and layerview as a preview of what will be printed.
