240 °C might be far too low depending on the ABS filament you are using. For example black filament normally needs much higher temperatures. Nature colored (not white) filament usually needs lower temperatures. But it truly depends on the material.
I NEVER print ABS below 250 °C because I want really tough layer bonding. The stock extruder is NOT designed for those high temps, at least for ABS where temperature is really critical compared to PLA.
Please share some pictures of your modified Ultimaker. I'm curious.
gr5 2,230
What? Picture please. This doesn't sound good.
Also try turning off the fan completely.
Why did you stop at 240C?
