2 hours ago, ahoeben said:Both of the things you want to do would be mainly in CuraEngine (which is written in c++), with some very minor work to enable settings for it in The frontend.
A new type of supports was recently added, you can easily find that in the closed pull requests in the CuraEngine project on github.
Thanks for your information. I think the support generation you've mentioned is https://github.com/Ultimaker/CuraEngine/pull/655 I'll probably change the thick trunk to thin tubes for SLA. Anyway it should make my job a lot easier.
Moreover, regarding the sliced preview in Cura, where the gcode path has been shown in different color, I guess it's done by Cura interpreting the gcode generated by CuraEngine. If so, should that part of Cura be changed to show raster images?
ahoeben 1,968
