Thanks for the reply.
I calibrated the lever too be on the safe side, and am now printing with a skirt and core2 in the correct position for now...
I will keep you informed if the problem happens again
But why in hell would it try to print the skirt with both materials as you suggested ???
fbrc8-erin 296
It may be that it's trying to do the skirt with both materials. Are you printing with a skirt? If you turn off the skirt, does it still try to start with Print Core 2?
Or is this happening during the leveling process? It should active level both Cores.
The printer should know which Core is down at any point in time by homing and going to the switching bay before any activities where it matters which Core is in the "active" position.
To be safe, you might want to go ahead and calibrate the lifting switch:
