Fusion360 stl file problem
Curor
Posted · Fusion360 stl file problem
I started by using Sketchup but quickly learned that it is not ideal for 3d prints.
I have now spent some time learning the basics of Fusion360.
It is very impressive, but I now ran into an unexpected problem.
My idea was to print a gauge block that would allow me to check the precision of holes printed in various objects.
I drew a block with one row of holes starting from 2.8 mm to 3.5 mm and one row going from 4.8 to 5.5 mm
I attached a copy of the stl file.
Nominal 3 & 5 mm holes are in the framed section.
When printing this the quality deteriorates badly towards one end of the print.
The end where the numbers 3 and 5 are printed comes out reasonably fine, but at the other end it becomes more of a topographical map of the rocky mountains.
Very rough and the printing nozzle snags on the hilltops during travel.
I have tried to adjust the resolution of the export from Fusion 360 and tried binary and ASCII file formats but no difference.
I also tried to reorient the printout to see if there was a mechanical problem with the printer in that area, but the problem occurs at the same location of the print every time.
I use Cura 3.2.1 to slice and a CR10 printer.
Any ideas why this goes wrong.
I am not worried about this particular item, but understanding what the cause is might help in more serious applications
I have printed several other objects drawn with F360 with great success, and by the way, the holes printed with very good accuracy.
Gauge.stl
    I think you would best post a couple of photos of the print, both a general overview, and close-ups. Anyway, expect the holes to become smaller than designed, due to the elasticity of the molten material when the nozzle draws the outline of the holes: it is pulled inwards. Just like a rubber band would be pulled inwards, if you try to lay it down in a circle and apply a bit of force to it. The smaller the hole, the worse this effect is. So, a 3mm hole is likely to end up as a 2 to 2.5mm hole.
    This seems to be a bit like when you have a problem with your car and bring it to a garage.
    Once the mechanic is there the car works perfectly fine.
    I had made 6-7 attempts to print this with disastrous result.
    They were all binned, so to get a sample to take some photos from I tried printing again, and it came out fine!
    The only change I had made between the files was that I had added a 2 mm fillet to the top edge around the block.
    Hard to see how that could make any difference.
    Holes did come out better than expected.
    A 3 mm precision steel shaft has a press fit in the 3 mm hole and a float fit in the 3.1 mm hole.
    I've checked the file in Cura, and looked at the mesh in Fusion 360, and there doesn't seem to be anything wrong with either that would explain why you would get a problem at one end.  The mesh is very consistent across the whole of the top surface, adding the fillets would have introduced more polygons but I wouldn't expect that to have made the improvement that you saw.
    If you got that level of accuracy on your final print then you have a very good machine, usually to get a press fit you need to add a compensation of around 0.2mm to the true size, and a float fit usually needs around a 0.3mm - 0.4mm compensation.
    If you experience the problem again be sure to re-post so we can see why this is happening.
        • 10 replies
