3 hours ago, mastory said:I've used Pronterface to do this in the past. The on screen controls can be used or the command line. An M92 Exxx code will redefine the extrusion constant which can be delivered via the command line in Pronterface if you want to change it. I think M500 on the command line would then save the change.
Thanks for the insight. Pronterface? Is that a software? I'm trying to do this in Cura and I don't see anywhere to enter the extrusion multiplier (if necessary).
nallath 1,120
Is it? I personally see it more are the manufacturer of the printer providing you the settings in the first place.
mastory 44
I see testing and resetting the extrusion constant as an essential maintenance and calibration procedure that anyone might need periodically. This is especially important to off brand or homemade printers or secondary market extruders.
