18 minutes ago, rebekah_harper said:I am going to need a little more help.
I thought that I could do it through putty but it's not recognising the commands
I did try through browser but that didn't seem to get me any where
cheers
Rebekah Anderson
Try to send other gcodes like G28 Z0 to home Z
if the E moves doesn’t do anything is probably because it has a minimum temperature protection. If um3 marlin allows it you should be able to send a M302 to allow Extruder movement when the tools are below 170C
1
neotko 1,418
You need to enable dev mode and access the machine using ssh root@yourprinterIP and the password is ultimaker
then using sendgcode you can send the gcode you want like “sendgcode G1 E10 F300” (where E is 10mm and F300 is the speed
Ofc the hard part is to change the esteps of the um3 since editing the json file can very easily Brick the printer if one comma or dot is misplaced
rebekah_harper 60
thank you for that.
I know, the bricking issue is at the for front of my mind but there is something bugging me about the upgrade I did and want to check it before I start getting emotional about it.
will let you know how it goes.
Rebekah Anderson
rebekah_harper 60
cheers
Rebekah Anderson
