12 minutes ago, gr5 said:Did you mess with the order of printing? I think it's supposed to be infill, then inner shell, then outer shell. Is this cura 15?
If this is cura 2.X or 3.X then search for "line width" above the parameters and make sure they are all set to 0.4mm.
Latest Cura (3.2.1), infill before walls, all line width parameters are set to 0.4.
gr5 2,210
I'm really surprised by this. 3 walls/shells each at 0.4mm should fix this issue. Even 2 walls. 1 wall -- I've seen this but not 3 walls.
