Is there a type that will create a kind of file selector filed ?
The user can type a file name or select it using a open dialog box...
A 'str' can be used to type a filename, but there is no file-picker/file open dialog box for a setting.
2 hours ago, ahoeben said:A 'str' can be used to type a filename, [...].
Ok I know str can be used to type a file name but the user can make mistake when typing it.
Thanks for your help I'll find a solution.
ahoeben 1,657
No, unfortunately, there is not.
