Problem Adding Post Processing Modify G-Code script
Posted
· Problem Adding Post Processing Modify G-Code script
Well, if you are running Cura 3.2.1, I would say that you should use C:\Program Files\Ultimaker Cura 3.2 instead of \Ultimaker Cura 3.0.
But the better place to put the script is in the configuration folder. In Cura go to Help -> Show configuration folder. In the folder that opens, there will be a folder named "scripts". Put your script in there.
ahoeben 1,955
tinkergnome 927
in addition: read the comments on thingiverse...
The file "cura.log" in the configuration folder should contain appropriate error messages (or warning), if a script can not be loaded.
