Hello, the issue went away this AM when I tried to print again. I'm not sure what happened, but it is working now. Is there a way to remove the topic?
Hi, I have similar problem, not the same.
Cura show my extruder temp as 0º and I check with another program PronterFace and says 16º of extruder temp.
So, in Cura 3.2.1 it doesn't start to print, always stay in "printing 0%".
In older Cura, I printed normally yesterday, with the same machine.
I cancel the print, and I can move correctly X, Z & Y axis... I tried to do it many times and it doesn't work.
Can you help me please? THANK YOU VERY MUCH
- 10 months later...
Was there ever an answer to why the temp of the extruder seems to be set to zero? It is set to 210 in settings.
gr5 2,224
You are the second person to post about this this week. This might be a new bug but if so I'm wondering why only 2 people mention it among many thousands.
So you are doing a dual print? PLA and PVA? Could you please check *all* the temperatures for extruder 1 in your cura profile? Near the top of the profile type "temp" in the search box. Show us a screen shot please.
Your screen shot looks normal by the way. It looks like its printing the pva in the photo and while extruder 2 is printing the pva, extruder 1 is supposed to be at the idle temperature which I assume is supposed to be 100C.
