Sometimes the issue is due to mismatched settings between Cura and your machine. Try deleting your machine profile and adding it back in. This will be under Settings-->Printer-->Manage Printers. Once that is done you should be able to connect your machine again to confirm if the live stream is no available.
If that doesn't work, try doing a Cura Connect Reset in the printer menu and/or hook it up via LAN to see if that changes anything.
1
EDTGprint 0
No one an idea? I admit that delivering live video is not the main function of a 3D-printer.
But if a webcam is built in, it should work in the designed way and not via a workaround only...
