Ok, i will give it a try with an even higher temp and layer height 0.2mm. When I tried printing ninjaflex the first time 2 years a go, I just wanted to try. The results were pretty good, which of course increased the expectations.
What I just don't understand is that the walls basically don't suffer from underextrusion but primarily the infill.
QuoteFlexible materials are not really considered reliable for bowden printing, so I wouldn't get my hopes too high regarding the expected results.
So, how do you print flex material reliable?
mastory 42
No experience with Ninjaflex. Assuming the printer is printing OK with more standard filaments, I would alter settings that would promote easier material flow. Maybe a bit hotter yet, or taller layers. Flexible materials are not really considered reliable for bowden printing, so I wouldn't get my hopes too high regarding the expected results.
