Assuming you use PLA, the less glue the better and squish the bottom layer very well. More details in this video. It's a long video but packed with all kinds of information about what to do and where you can actually watch it happening so you know better than with words:
Nicolinux 288
Hi and welcome to the forums.
It depends on several variables. But in general you don't need that much glue (if at all). Depending on the model you are printing and the filament used, there are several strategies to use.
Which printer do you use?
Which filament do you use?
Which slicer do you use? (Cura?). If yes, which print settings did you select?
