Carbon fiber filament
praveen
Posted · Carbon fiber filament
Hi
I am using Ultimaker 2 extended+ 3D printer.I have some doubts about printing parameters for about corbon fiber filament
1. Can we Corbon fiber filament in Ultimaker 2 Extended+ printer..???
2. If yes What are the parameters i need to change..??
3. I have tried Corbon fiber filament but it is printing but after  couple of hours the nozzle gets clogging..??
it woluld be great if any one help me out.
    What temperature are you setting to print for this?
     PLA print temperature is typically 185 to 205  degrees Celsius.  Carbon fiber is a bit higher
    Carbon Fiber Print Temperature typically is : 240-260 degrees Celsius
    Hi
    I am using PLA settings like Temperature 210-215 Degree Celcius, and can you please tell me what are the print parameters need to change. I am using 0.6 and 0.8mm diameter nozzle.
    • 1 month later...
