I think the button works fine, but then you could have back places at the top of the menu lists instead of at the bottom, which would make much more sense and then no wrap around
Also when selecting items in lower horizontal menus, wrap around is totally not useful only making it harder to use
lower horizontal menus?
do you mean the CONFIRM IGNORE type buttons at the bottom of the screen with text above?
yes, confirm / ignore or <return / confirm buttons
I don't think those should be wrap around, I'll check.
robinmdh 93
I'm actually quite happy that it wraps as you can then quickly exit a bunch of nested menus by directly going to the bottom... this counts even if there are 3 times since then I don't have to think about it too much, but if the button is giving you trouble then I suggest replacing the knob https://www.youmagine.com/designs/lofted-um2-knob, https://www.thingiverse.com/thing:2172449 or https://makerware.thingiverse.com/thing:832197
I suppose we could make it a setting but in a lot of cases where buttons are shown itself a flag is already being set to allow wrapping the screen or not since after reading a bunch of text you don't want to skip back to the beginning of the text...
